Variator Order
Discussion in 'Maxiscooter Tuning' started by Anton Kash, Feb 4, 2012.
  1. Anton Kash
    Anton Kash Member
    Typh
    I have just finished rebuilding my bike and I'm going premix, Do I have to install the oil pump and all the bits still or can I leave ALL the oil pump stuff out, I thought some bits are need as a spacer or something. What is the order of everything on the varitator crank shaft?
  2. Jonnymarrw00t
    Piaggio Zip 05 plate
    If it's the typhoon, then you just need to leave the spacers that go behind the variator.
  3. Anton Kash
    Anton Kash Member
    Typh
    It would help if you could put the order of everything that goes on the crank, not only for me but encase others need to know. E.G - Variator spacer, belt, pulley
  4. Jonnymarrw00t
    Well from the back you've got the oil pump belt spacer(Grooves cut into it) then you have a metal spacer, then your variator,metal spacer through the middle of that, then your belt, then the drive face, fan holder, then the variator nut.
  5. Anton Kash
    Anton Kash Member
    Typh
    so everything you mentioned is needed?
  6. Jonnymarrw00t
