Uselss Rear Drum Brake
Discussion in 'The Workshop' started by samt8569, Oct 22, 2011.
  1. samt8569
    samt8569 New Member
    Alright guys,
    So yeah, as the title says my rear drum brake is 95% useless. I'm not quite sure on exactly what has happened but it used to be alright, but no brilliant. I've tried tightening the brake so that there's no play in the lever at all. I can still pull it all the way right back the grip and still accelerate pretty quick away.
    I'd quite like to have trust in my rear brake as i'd like to learn how to wheelie, but with the brake in its current state im not even going to bother. I've seen other bike which drum brakes are insane!
    So, if you were in the situation im in, what would you do? The bikes a Peugeot Speedfight 2 if thats any help. Could it be that it just needs adjusting?
    Any help whats so ever is good.
    Regards,
    Sam.
  2. phil.s
    phil.s Active Member
    have you checked the brake shoe's for how much material is on them ?
  3. stkflote
    stkflote Member
    zip 2t cat
    it probably needs new brake shoes,,you cant keep tightening adjuster up you will end up needing a new wheel,take it out and check the brake shoes
  4. tErr0
    Could need a new cable if it's been fully adjusted and it's still not doing anything. They can stretch over time.
