Urgent Help!!!!!!!!!!!!!
Discussion in 'The Workshop' started by CrazyJames, Jun 12, 2009.
  1. CrazyJames
    CrazyJames Member
    Ratty Runner 172
    I need to mod this (in the Pic) so the fuel runs through it freely so i can add a fuel tap into the fuel line, If any1 know how it is done the plz plz plz let me know asap :)
  2. Burns
    Burns Active Member
    Aprilia sr50
    dont think you can? :confused:cratch: there built to flow by vacume i think it might just fuck it up if you block the vacume section.
    suzuki katana ones are tap, not sure which other scooters use the tap
  3. safekyle
    safekyle New Member
    Gilera runner 172
    Urm, katana pump.... lovely to use when your trying to drain a tank :hmm: .
    just create an airblock. blow into the vaccuum really hard. then block it with your hand or put a cork in it.
  4. Burns
    Burns Active Member
    Aprilia sr50
    if you block the cavume no fuel will come through. just snip the main line and conect a tap onto it somewhere
  5. jimbo180cc
    jimbo180cc New Member
    buy a gravity fuel tap, it has a lil nob on the end so you open it when start you bike and close it when you turn it off, just dont forget to shut it :blush:
    shhould i say you would fit this gravity tap where the origanal goes
