Urgent help needed
Discussion in 'General Scooter Discussion' started by sussexlad, Feb 14, 2024.
  1. sussexlad
    sussexlad Member
    I started a post last month regarding my Piaggio Medley
    anyway cut a long story short i lost my master key
    but did one the master key a week before i lost it
    anyway the new key that was cloned i did not know at the time needed to be paired with the brown key (it was working so i assumed it was not needed )
    the new key does not work now I assume the immobiliser needs to be programmed to the new key
    I’m not left with one key that was cloned from the master key that does it start the bike (it will on rare occasions start but most the time it won’t i get two flashing lights where the temp sensor is that flashes twice then stays solid )
    I need to get this sorted but not sure where to turn to
    i guess it’s going to be expensive
    anyone in south east that can assist or that people can recommend ?
    i can’t strip the bike myself so need someone to come to me
    failing that perhaps a work around can be done as i have the chip that’s been copied from the master key but its not enough to start the bike
  2. MARSH
    Malossi used to make a CDI that replaced the immobiliser on the old et4, it might work on yours?
