Upjetting standard carb
Discussion in 'Newbie Scooter Tuning' started by Makaveli123, Oct 6, 2011.
  1. Makaveli123
    Makaveli123 GHOST RIDER
    Aprilia RS50 2004
    Hi there! :) at the moment i have a TNT air filter and i want to put it on my original Dell'Orto PHVA 12DD carb. i take it the carb will need to be upjetted? is it the main jet i change? my haynes manual says the main jet is 66. i was thinking 0.80mm jet? Help please?
  2. xplicit vehicle
    xplicit vehicle Member
    PGO Big Max 50
    are u putting that air filter on a standard bike.....
  3. Makaveli123
    Aprilia RS50 2004
    erm yeah...
  4. Honda.Dream
    Honda.Dream New Member
    Honda Sxr50
    It should need that much I believe, I've read somewhere it needs a 10% jet increase(not sure thou)
    if your engine hasnt got any other mods give it a try without upjetting it, let it warm up, up and down the street at WOT stop, let it cool down and check the plug colour.
    Bit if you have an aftermarket exhaust you better upjet, it will seize otherwise. never good...
    Good luck :)
  5. tErr0
    Or just don't do it. Complete useless mod on an otherwise standard bike. It will generally increase the noise, reduce the performance and use up more fuel.
    So pretty much don't do it as it is a no gains mod that if you get the jetting wrong will seize your bike up pretty quickly.
