Upjetted and air filter
Discussion in 'Newbie Scooter Tuning' started by CA Zip tuning, Mar 22, 2012.
  1. CA Zip tuning
    CA Zip tuning Member
    got my air filter on my ped upjetted to an 80 jet its running better but might go for a 90 and see how that is. My accleeration has improved but my top speed has decreased by about 3 mph is this supposed to happen? cheers
  2. 2many2strokes
    zzr1400
    is the bike bogging on full throttle??
  3. CA Zip tuning
  4. Jonnymarrw00t
    Piaggio Zip 05 plate
    You need it on the dyno.
  5. CA Zip tuning
    does it have to go on the dyno also theres a black wire with a blue line down it hanging out its fallen out of a tiny hole in something that looks like a cap theres another wire thats in there properly what is it ?
  6. 2many2strokes
    zzr1400
    Are these wires on the carb?? if so could be from the auto choke. I would try goin up a size on the jet might slightly lean.
  7. CA Zip tuning
    wires on the choke mate
  8. 2many2strokes
    zzr1400
    probably from the auto choke, try to reconnect them that may have an effect on the running issue.
  9. Jonnymarrw00t
    It'll run rich if the choke is always on. But as I've said jet is still far off. Try a 110 garuntea it'll be better. I've been anywhere from a 96 with restrictors to a 120 on a standard zip with a filter.
  10. CA Zip tuning
  11. Jonnymarrw00t
    You need a new choke.
  12. CA Zip tuning
    Ok mate do i need a manual or automatic one and can i still ride it at the moment like it is or not ?
  13. Edgar
    Edgar Active Member
    choke only works when you start the bike from cold , if it starts fine you can ride it like this until u get another one
  14. CA Zip tuning
