My ped seized today it just died and now it goes 10 metres and dies my mate from Walton Road Garage telling me it seized so probably is but how can I fix it while im looking for a Typhoon 125 block or Gilly block(Contact me if your selling)How can I unseize it.
you can not relly un seize an engine, you need to take the head off and have a look at the condition of the piston , rings , and barrel , if the cylinder is not scored or warped , and the sleave of the bore is fine then change piston and rings, and run in proply , genrally when sezuire happens it will normally envolve somthing being replaced , really u need to take the head and barrel off to have a propa look and see if you can figure what coursed it to seize , ow many miles has the engine done.
its donme about 300 miles with it in and i didnt fill it up with oil once sinice i put it in?? so im guesing thats why
:msn1: :msn1: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :rtfm: :rtfm: :wallbash: :rtfm: :rtfm: :wallbash: :rtfm: :wallbash:
I check it daily. could have had an oil leak over night, in london someone cudda pulled the pipe off and nicked your oil everymorning i check it
My oil light works when i turn over, just doesn't work when its low, do i need a new sensor or whatnot o.0
http://www.scootershack.co.uk/viewtopic.php?t=4760 Unseized?......go on, someone criticise honing out a barrel. You may knock it, but for £20 it's worth a shot, and mine runs fine now..
Same thing happened to me when i had my dragster seized on a3 on a monday morning school run times going down a underpath!!! Was fucked lol
