Tyre???
Discussion in 'The Workshop' started by The-predator, Nov 15, 2007.
  1. The-predator
    The-predator New Member
    im a due a new tyre and just wondering if a 130/70/13 will change gearing as its got a higher side wall (larger tyre), ive got a 120/70/13 on at the moment ?
    Thanks
  2. wobbly_trials
    chances are you wont know any different, higher side tyres tend to have a less curved face.
  3. MiNoR cOnFuSiOn
    erm, thas a thinner tyre not a larger profile... :confused:arc:
  4. wobbly_trials
    fair point there.
    i thought it was height of sidewall/width of tyre (in percent of height of sidewall)/rim size
  5. MiNoR cOnFuSiOn
    will run a smaller profile if the width is smaller on the same profile as the tyre stretches over a larger area hence looses profile. will loose top end and basicly its illegal and dangerouse. dont play with the width. if you wanna drop to a 130/60 you can do to give you a little more grunt and tighter handeling, ride will be bumpier tho
