Typhoon xr 125 fuel pipe size
Discussion in 'The Workshop' started by Nick Kruklinski, Feb 1, 2014.
  1. Nick Kruklinski
    Nick Kruklinski Member
    Typhoon XR 125
    As it says in the title what is the diameter of my fuel pipe from the tank to my carb discovered a split it mine when I got to work. I'm guessing its 5mm but don't want to order the wrong size any help is great.
    Thanks Nick
  2. MARSH
    5mm would be ok.
  3. Nick Kruklinski
    Typhoon XR 125
    Thanks Marsh. Don't suppose you know a quick fix until the new one arrives do you?
  4. MARSH
    On the 125 typhoons there should be an overflow pipe that run's down the l/h side of the frame down to the floorboard, you could cut a length off that to use!
  5. Nick Kruklinski
    Typhoon XR 125
    So if I take my floor board off look on the left side should see it. Cheers for the reply
  6. MARSH
    No, just the panel under the front of seat, where you check spark plug, the pipe should be on the left, tucked behind the side panel.
  7. Nick Kruklinski
    Typhoon XR 125
    Is it common for them to leak at the breather pipe at the bottom of the carb. As looks like mine is
  8. MARSH
    Mine sometimes leak's especially when I've filled up when warm, it could be the float needle leaking, you can buy a needle set for the Mikuni carb.
  9. Nick Kruklinski
    Typhoon XR 125
    Cheers mate for the help and advice :) much appreciated
