Can you use the standard throttle system? Can I use a quick action throttle without any body modification? Any info plz
What's the throttle options running a 28 on premix? Keeping standard handlebars and clocks, could I use a universal throttle cable or is quick action the way to go?
Definitely. The s6 straight cable works with the standard throttle on a 28mm but full throttle can hurt after a bit so not really the best. Its hard to get around the cutting. Domino make a nice one with slightly more pull than the normal one and doesnt need any cutting but its also about £70 and isnt stocked anywhere..
Anyone used the metal manifolds and larger reed blocks? PSN seem to have their own one, shiny had developed some a while back but there 183 builds use a stage 6 and sip use an rd350 reed block based manifold reed block kit. Are these kits moving away from road use and based more on drag scooters? Also can I get main bearings from Malossi for Typhoon 125?
I would also like to know what needle is best suited in a keihin 28mm pwk for a 172. Anyone with an SRT build or just using a Keihin 28 care to shed some light please?
