i no that the nrg front panels can be changed with a typhoon front panels but do the typhoon back panels fit on an NRG ???
nrg frame is identical apart from 2 bits that stop the typh pans fitting... nrg pannels will go straight on a typh but there is nowhere to mount the spoiler.. the nrg frame can take typh pans but you have to remove most of the rad mount at the front and chop out the rear spoiler mount,, the rear its a good idea to weld in some support as its a fair bit of crossmember your removing from the back.
ok cheers .. was thinking of doing it as i seen this on ebay today http://cgi.ebay.co.uk/2002-PIAGGIO-NRG- ... 286.c0.m14
i had a nrg frame once and there was a bit on the back for the spoiler you could just unbolt the little bit and it was a typh frame bolt it back on it was a nrg if you see what i mean but i think it was an old frame
