just bought a spanking typhoon 125 bored it up to a 172 drove it home. went to drive it today and when i stared it it was fine on tick over, but wen i went to give it more den quater throttle is stared making a loud squeaking noise?? i think it might be the belt when the clutch engages and spins the back wheel. but am not shure any ideas would be great. thanks
I have exactly the same problem with my typhoon. Wears off after the engine is really warm though... Haven´t figured out whats wrong yet
its the vario. need to litgly grease the cylinder type thing that goes through the midde of the variator i think.
i have the same problem when my sr is cold as soon as iv road it for around 5mins it goes. not to sure what it is though sounds like it comes from the cylinder.
ah ok i didnt want to drive it because i didnt want to f**k up the bore i took the tranny off but everythinks fine. i left it warm up for about 5mins today and its still doin it. would you say its nuffink to worry about as yours do it?
everyone used to wc's ask's about this.. as said grease the insside of the variator between the copper/brass inserts(slight bit is fine) and the pins on the torque drive.. replace the belt if the squeek percists also grease behind the oil pump drive gear as its a friction mount wich relys on softer material to smooth running, basicly saps power and wears quick. can also cause a squeek when cold
