hi guys, I have a piaggio nrg mc2 2002 reg could anyone tell me the standard disk size for: Piaggio typhoon piaggio nrg mc2 i only ask as i bought some forks and they are off the typh and everything fits as it should except the caliper wont fit with the disc that is on the mc2 wheel, what i need to know is does the typh have a smaller disc (think the mc2 is 190mm) or does it have a slightly different caliper? cheers guys Sent from my GT-N7100 using Tapatalk 4
The reason a mc2 wheel fits is cos the disk is the same size as a typhoon. An nrg wheel with a 190mm disk isn't a mc2 wheel
Sorry i think i left bits of info out the wheel, caliper and disk are off the mc2 the forks are off a typhoon the wheel fits the forks but the caliper wont fit cos the disk seems too big What im asking is does the typhoon have a smaller disk and the same caliper or does it have the same disk and bigger caliper ? Sent from my GT-N7100 using Tapatalk 4
If its anything more than 3 its deffo the wrong wheel If it was a mc2 one it would bolt straight on as they used the same calipers and disks as the typhoons used to
this is the only picture i have of the scoot atm What it is, is that the forks were knackered and the only ones i could fing were for a typh so i have put the forks on and the wheel fits the forks fine im just stuck trying to sort the caliper out :/ Sent from my GT-N7100 using Tapatalk 4
Thats something i didnt want to have to do is there not a caliper that would fit ? Sent from my GT-N7100 using Tapatalk 4
Just buy some nrg Mc3 fork's, the typhoon fork's/ wheel use a straight spindle, ally speedo drive. The Mc3 has a plastic drive, pinch bolt spindle.
Getting things sorted now made a new spindle in work today just need to check the diameter of the disk that is on the wheel wich if i am right will be a 220mm disk for the mc3 and if it is i have found a 190mm 5 bolt disc to replace it with and if all goes well it will be finally ready for mot next weekend woop and will work out a lot cheaper than another set of forks Wish me luck Sent from my GT-N7100 using Tapatalk 4
Made the damn spindle about 25mm too long oops my bad will adjust that in work tomorrow morning and the good news is the disk is 220mm thanks to you guys pointing me in the right direction so just needs a 190mm disk slipping on and she will be sweet Happy days Sent from my GT-N7100 using Tapatalk 4
No the caliper is the same fitment just needs the smaller 190mm disc instead of the 220 that i have on the wheel atm Sent from my GT-N7100 using Tapatalk
