Typhoon - Forks have no travel
Discussion in 'The Workshop' started by Storm, Oct 15, 2013.
  1. Storm
    Storm Member
    Nothing atm
    The front forks on my typhoon have no travel, I can put ally weight on the bike and bounce the front wheel of the floor and the forks will not compress. Am guessing this is seals, oilor springs. Maybe a combination. Haven't had them off yet as have a broken wrist.
    Wandering what's the most common reason and if the forks are serviceable or recoended to get a new set.
  2. PDBV
    PDBV Member
    I would say get a new set pal i had the same problem with my nrg and was advised just to replace them
    Sent from my GT-N7100 using Tapatalk
  3. Storm
    Storm Member
    Nothing atm
    Thanks for the response, it seems that everyone replaces there forks instead of reconditioning them. They actually pretty healthy so may just need regreasing, i guess if i'm going to change them its worth having a look anyway.
  4. PDBV
    PDBV Member
    Yeah worth a look i suppose mine also had corrosion on the legs so would have needed re chroming
  5. MARSH
    I have only ever fitted new bushes to typhoon fork's once years ago, never again will I do it, it's realy not worth the headache as there a crap design, I just fit new fork's to mine full stop.
  6. Storm
    Storm Member
    Nothing atm
    Whats been the life span of your forks roughly?
  7. PDBV
    PDBV Member
    I have no idea ive only just bought my mc2 with duff forks so not got a clue lol
  8. MARSH
    I got about 5 ish years out of a set, you do need to drill a hole near the top of each leg and spray in some chain lube and oil of some kind to keep them good. It all way's leak's down the legs but keeps them from rusting, just wipe the oil off for mot.
