was changeing the rear tail/brake light when all the lights went off , the petrol gauge is working go's up and down and the horn is working but no lights? elecy start not working ither. what fuse runs the lights and elecy start.cheers
will probably be the fuse next to the battery.... if not then it must be one of the 3 up front (removable peice on the inner front pannel) chances are the positive is earthing tho so whip the light back out and check a, you have everything in the right place and b, the blades arnt bent towards the frame but downwards.... there a pain to get in somtimes but bending them upwards to make it easy just makes the positive go to earth, this will kill ALL your lights
think its the fuse next to the battary , just pulled it out and the blades got black on them and the plastic body has got brown marks on it lol
