Typhoon 55mm crank
Discussion in 'Maxiscooter Tuning' started by Admiwal Wabbit, Apr 5, 2011.
  1. Admiwal Wabbit
    Admiwal Wabbit Member
    Got a 55mm crank here which I'm tempted to buy. MUST you do the transfers etc in order for it to run ok on a 172 kit?
    Mike.
  2. grantmc3
    grantmc3 Member
    piaggio nrg mc3
    you dont have to do the transfers it will still run but you will get much more power if you get it done by a professional.
  3. tErr0
  4. Admiwal Wabbit
    Yeah I figured so. Will need to find someone who can do it for me then. I'm not going to attempt it myself :p I know a 1.5mm plate will be needed.
    (I know I am trying to do things the easy way here)
    Could I not just fit something such as an advance/retard unit to correct the timing and prevent detontation?
  5. nrgandy
    nrgandy New Member
    contact shiny or minor confusion they should be able to help you. or alternativly i have a a/c 172 that has been ported by minor for a 55mm crank also have a mint bgm crank too low miles etc and new piston etc pm me if interested
  6. MiNoR cOnFuSiOn
    if you dont correct the ports you end up wiht a 3mm step at bdc.. this means the engine produces ev en less power than with a 52mm crank. DEFFO need correction fo some kind :)
