Typhoon 125cc
Discussion in 'Maxiscooter Tuning' started by Kvh, Oct 8, 2017.
  1. Kvh
    Kvh New Member
    I have a typhoon 125cc 2T with setup:
    Malossi kit
    Malossi gears
    25 carburetor
    Malossi variator
    With standard 180 muffler
    What’s the best ( color )clutch springs to use with this setup ?
    Hope to see a response soon.
  2. MARSH
    AIl all depend,s on what you want from it? it will work fine with std clutch/variator, even std carb just up=jetted.
  3. Kvh
    Kvh New Member
    I forgot to mention I want it for drag races and long run
    What’s the best ( color ) clutch springs you recommend
  4. MARSH
    With your set-up Std springs would work fine. All depend's on you? Are you 8 stone or 18 stone? you need to set it up until it feel's right, there is no set guide on set -up. It might sound as if I'm not trying to help but you need it driving/pulling without it revving it's nads off, it will run great. When you have a crank/pipe then you'll need to play with springs/rollers. And I would suggest it be a "drag" scooter OR tourer !
  5. Kvh
    Kvh New Member
    Ok then I will get back to you for more information soon .. # drag scooter
