typhoon 125cc cdi
Discussion in 'Maxiscooter Tuning' started by ledge, Nov 24, 2007.
  1. ledge
    ledge Member
    hi do they do a race cdi unit for a typhoon 125 i cant seem to find one? and also iif they dont use ont can i use a gilera runner stater and the malossi cdi thank paul
  2. MiNoR cOnFuSiOn
    nah, the ac stator is a peice of shit really.. use the wc stator with the wc flywheel and tap the holes for the fan screws. then you can fit a malossi cdi. tbh its not worth it unless your doing seriouse engine work but the wc stator works wonders on an ac engine alone
  3. ledge
    ledge Member
    well i have got a wc starter so mite aswell use it the sec of the bike is a typhoon 125 engine with
    malossi crank
    malossi exhaust
    mallssi clutch and varitor
    28mm carb (caould u please give me a jet size to work down from thank)
    and matched csign and matched exhaust port
  4. MiNoR cOnFuSiOn
    jet will be around a 110 down..rollers around the 13.5 mark
  5. ledge
    ledge Member
    hi pal i hv got 2 carbs i hv got a delltro 28mm and also a koso flatside 28mm wot will be best to use thanks paul
  6. MiNoR cOnFuSiOn
    dell, as its not a copy of a decent make, it is a decent make so setup will be nice an easy.
  7. ledge
    ledge Member
    that what i was going to use, i now they r gd carbs and quite easy to set up! could u give me sum mesuerment to what to take the parts and and tranfer ports to please as sum1 is doing it for me one day in the weeek thakns paul
  8. ledge
    ledge Member
    deoends how much? what iss orung with the flatside u r using the carb is nearly brand new got used to run a rs125 int then had bigger carb fitted
  9. MiNoR cOnFuSiOn
    not gona give you inner port mesurements but the inlet feeds should have around 4mm left once ground. all im giving out ;)
  10. ledge
    ledge Member
    lol fiar enough!
    how much to port and match the crank cases and to match the exhaust stub
  11. MiNoR cOnFuSiOn
    200 for case and barrel in and out no internal no build
    300 for inner to road/race spec.
    add 60 quid if you want it built
  12. ledge
    ledge Member
    os there any chance for a littel bit cheep mate? where abotu are u based i will probily hv to post the bits to u
  13. Sw1fT
    Sw1fT Active Member
    200SX S13
    he's in south london
  14. MiNoR cOnFuSiOn
    no chance.. jb charge a grand for the same work
  15. ledge
    ledge Member
    ok pal i will do it for the 300 if u pay the poastage both ways pal thanks paul
  16. MiNoR cOnFuSiOn
    got a set of pre-ported wc cases sitting here...could buy them if you like
  17. ledge
    ledge Member
    ye that would be gd if there a gd price, ive allready got a miledy ported 172cc ac kit for it
  18. MiNoR cOnFuSiOn
    ok, have to pm me pics of the barrel as it might have been done badly for all i know and ill have to match it.. i want 250 for just bare case..then send ya barrel down an ill nock a bit off for the matchin then whatever else you want done we can talk ok.. ;)
  19. ledge
    ledge Member
    it s was off sum1 who youst to race it on x race (it was a blue gilera ice with typhoon lump) cant remember his name muite be itrested could u do it for 250 and match it up to my kit and makes sure everuthing is ok
