What I the standard original carb for my bike please? Is this it http://item.mobileweb.ebay.co.uk/viewitem?sbk=1&nav=SEARCH&itemId=360766801877
Yes it is, that carb may be jetted slightly bigger as it say's it's for a runner, the typhoon main jet is a 82.5, slide and needle should be the same but not 100% sure. Have you problems with your existing carb?
Okayy cheers that makes sense and yeah I'm having trouble with a dellorto phl 25bd needs setting and all that and its just not really working out so I'm gonna go standard unless you have any recomendations
The std carb work's very well even on a kitted engine, I had to buy a carb off the German bay because I couldn't find one in the UK. £75 inc post as I could not get a 20.5mm dellorto to work.
Yeah I find the dellortto useles I bought the bike as I project and it hasn't been running properly at all I need someone with time on their hands and spares to come and help tbh + do you have to upjet when 172ing
Yes, the typhoon carb uses the same main jets as the dellorto (6mm), upjet to 90-92 ish with a 172 kit, std exhaust, slightly bigger if using a good pipe.
Okay cheers yeah I'm gonna use the standard exhaust and my local said they have no carbs in stock I don't mind purchasing one of e bay but it's not the original carb and I just wanna instal ASAP. Has anyone got a spare mikuni vm20 for a typhoon xr ? Will pay
So I've jetted the bike up to a size 83 and it's running way too rich no throttle response at all it was 50 before but I'm not sure where to go in between with such a big carb the 50 seems rich but I haven't run it on the airbox ? Just foam any ideas ?
