typhoon 125 ..to buy or not?
Discussion in 'General Chat' started by billyboi, Dec 10, 2008.
  1. billyboi
    billyboi New Member
    hey im going to look at a typhoon 125 later he said it need fork seals and a headset
    its a 2002 model and standard bar malossi belt and rollers
    wants 350 for it what do you think?
    also what shall i look for on it to see if its fuked lol cheers
  2. connor
    connor Active Member
    sounds alryt. make sure all elctrics work. make sure frame numbers match loggy an see if its got engine numbers if not ask why ect..
  3. billyboi
    billyboi New Member
    ok mate where the frame an engine nums on a typ? cheers
  4. connor
    engine numbers are at the back near the brake cable on a lil plate. not sure about frame number tbh.
  5. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    pretty sure the typhoons have the frame numbers on the right side of the belly pan, just underneath it
  6. stuart2k7
    stuart2k7 New Member
    Dragster 172
    My 2000 typhoon 125 has the frame number on one of the inner panels.
  7. m1ck_t
    alot of shit
    :confused:arc: :msn1: :wtf:
  8. connor
    lol do you mean under 1 of the inner pannels?
  9. Sh0x
    Sh0x New Member
    under belly panel there is a part of the frame with vin number, visable with bely panel on as its designed to be seen.
    fork seals can be expensive to have done, forks are most likely leaking badly or siezed solid, solid forks in this weather are dangerous, avoid. COmmon.
    typhoon electrics usually play up too. throttles are sticky and brakes are usually bad.
