typh starting problem
Discussion in 'The Workshop' started by mattyfin94, Sep 5, 2010.
  1. mattyfin94
    mattyfin94 New Member
    typh 70
    I am having problems starting my typhoon, i recently had it tuned by tdr and it was running fine but unjetted slighlty. i took it bad had a service and also a polini variator fitted . ever since then when i open it up a little i just jolted back and cut out,, and started about 5 mins lateer. now it wont start atall. i checked everything and all is good except i noticed the piston is badly scored. could this be the fault of it not strarting. and it is turning over. cheers :confused: :confused: :confused:
  2. aerox crazy
    aerox crazy New Member
    Well first get the plug out check colours of the plug then report back .Whilst doingthat put the plug on the head and check for a nice spark .
    A way to see if its a fuel problem is put a little of fuel into the cylinder were the plug goes, if it starts then your not getting your fuel mix to the cyclinder.
    A scored piston would corse problem ,but saying that my aerox had a very badly scored piston and went fine still will , with another set of rings and gasket but id would rather put another kit .
    Any way do that then report back. :)
  3. mattyfin94
    typh 70
    cheers for the reply,, i tried the spark its fine and i also checked if its getting petrol which it is :/ still not starting, and i am confused because the piston has been scored for quite a time i check the whole engine over carnt fine one problem :(
  4. DASH.
    DASH. New Member
    Zip 70.
    check your oil, sounds to me your running dry?
  5. mattyfin94
    typh 70
    to check the oil is the dipstick by the real wheel, if so i have enough oil
  6. BossMan172
    BossMan172 Member
    aprilia sr 172
    no thats ur gearbox oil...you checked ur reeds..put them to light and if you can see any through the block, where the reeds meet it then you need new reeds
  7. bertie
    bertie Active Member
    '93 Skipper LX125
    If you've taken it to a tuning shop, had work done then got it back running shit why not just take it back to the shop and ask if they would sort it.
    Should be free of charge since they last touched the bike, it supprises me sometimes how shops can give people their bike back running like shit.. I would be embarrased to return a customers bike running badly.
  8. mattyfin94
    typh 70
    i am taking it back wednesday :) there parents were in hospital i checked the reeds and one was chipped but showing no light what so ever through :confused: :/
  9. DASH.
    DASH. New Member
    Zip 70.
    if it was chipped then that was what was doing it they need to be full or they let in to much petrol i had this happen to me a wile ago
  10. mattyfin94
    typh 70
    i just literately put my standered reed petals back in still not starting. think im just gunna have to take it to tdr, to solve it. im thinking its the scored piston and cylinder :/
  11. DASH.
    DASH. New Member
    Zip 70.
    If it is they should sort it
  12. mattyfin94
    typh 70
    yeh :) dont want to spend to much seeing that i only started riding on the 70 kit in july. but im going to have to dish out. :/i heard that if the bike is unjetted it can also score the piston? this true?
  13. DASH.
    DASH. New Member
    Zip 70.
    No upjetting wont score the piston
  14. GUNS
    GUNS the usual suspect
    racing SP70 & LX172
    if it's UNJETTED to suit the mods............. it can melt the piston. :)
  15. DASH.
    DASH. New Member
    Zip 70.
    My bad its late :blush:
  16. mattyfin94
    typh 70
    im just going to take it to tdr and se whats what, cheers guys :)
  17. Rhysss
    Rhysss New Member
    Gilera Runner SP125
    Off topic here a bit but another scooter rider 10 mins from me who actually has a nice ped and not some shite import :D lol
  18. mattyfin94
    typh 70
    and who has a shit import?
