typh rear disc?
Discussion in 'The Workshop' started by kobster, Jul 15, 2007.
  1. kobster
    kobster New Member
    i heard that it possible to fit rear disc in typh if i changed engine casing new generetion, its true?
    someone can give me explain?
    thanks
  2. wobbly_trials
    you need a new style engine (with brake caliper mounts), a runner or dragster hub, wheel, disc, caliper and master cylinder.
  3. MiNoR cOnFuSiOn
    you can hook up a typh front master cylinder to the frame and shorten the cable with a diff end on it. basicly means you can run a cable to the cylinder wich feeds the rear. easiest is the whole system off a runner tho.
