typh 125 small drum lc conversion
Discussion in 'The Workshop' started by gemini, Oct 12, 2014.
  1. gemini
    gemini Member
    Hey people cant seem to find the correct info for whats needed to convert my small drum 125 typh engine into water cooled. Does anyone have any links or know exactly what i need to convert thanks
  2. MARSH
    You need to have the r/h engine case machined to accept the metal bottom hose, run an electric water pump/rad etc. Some would say just use a runner r/h half case but I'd prefer matched cases.
  3. gemini
    gemini Member
    Would you no how much that would cost and do u have any pictues of how it looks. So when u say a runner r/h case do u mean the case for the other side of the crank or the case that has the tubes for the coolant or would i need both thanks
  4. MARSH
    It would only cost £10-20 as it's only a machined hole, the runner crank cases are the same as typhoon so in theory you could just use the runner half case. I wouldn't as most cases are machined as a pair.
  5. gemini
    gemini Member
    Ok thanks ill look into it
