typh 125 lights problem
Discussion in 'The Workshop' started by GeorgeMorriss, Aug 18, 2013.
  1. GeorgeMorriss
    GeorgeMorriss Member
    my typhoon 125 head lights wont come on even though it is wired up correctly? i have the tnt halogen bulbs in carbon effect.
    also my rear light will stay very bright all the time when the light switch is turned on, they wont stay dim they just stay bright, yet when the light switch is turned off they stay off and go on dim when the brake levers are pulled? help?
    does anyone know of any websites where i can buy typhoon standard parts as i need a standard bulb unit aswell.
  2. ziggy_tph125
    ziggy_tph125 SONIC BOOOOM!!
    Piaggio Typoon 125,
    in my area (west london) c.b.s whitton sell all the bits i need, i also have a typhoon 125, sounds to me like a wireing problem to be honest but im no pro. have you looked at the switch on the break leaver?? it could be sticking making the break light stay on? i would check both if it was me......
  3. Merlin
    Merlin Old School Biker
    2007 TKR WRC 50
    The brake light switches have a habit of working loose (they did on my Pug, until I fitted new ones). If they have not been pushed fully home into the levers, they will keep the brake light on. The lights coming on dim when the brake lever is pulled and the light switch is off hints at a bad earth or damaged wiring.
    Have you ever been behind an old Fiat, Ford or a trailer that turns into a mobile disco when the indicators are turned on, with lights going on and off and you don't have a clue which way they are about to turn? That's a problem similar to the one you've got. Check all of the wires that go to earth and clean the battery terminals.
    ziggy_tph125 likes this.
