tunning help
Discussion in 'General Scooter Discussion' started by mitch70, Jun 16, 2011.
  1. mitch70
    mitch70 Member
    typhoon 70
    im looking for a good 70 kit what is fast and will last me for my piaggio typhoon
  2. mattyhook
    mattyhook New Member
    honda x8r
    stay away from the PM kit it will be rapid the first month then after that nothing but problems. its happened to 5 or 6 i know who used to use the kit.
    polini is always a safe bet.
  3. Gamble
    Gamble Member
  4. mitch70
    mitch70 Member
    typhoon 70
    i want something reliable and fast was not to pricey i was looking to buy a malossi sport or polini sport and a pm tunning 360 pipe may b a 21mm polini carb
    thanks for that add it was helpfull
  5. Gamble
    Gamble Member
    Unfortunately you can't get all three, it's two of the three.
    You want something not too pricey, that would point me towards the sport range.
    Something reliable, once again would point me towards the sport range.
    Something fast... They're torquey and great fun to ride, if you're used to a 50 it'll make you smile!
    I'm basically trying to say, I'd recommend a sport range. :good: Just make sure you pick an exhaust that suits it (link above) and that it's setup properly. A bigger carburettor would also be a step in the right direction.
  6. mitch70
    mitch70 Member
    typhoon 70
    thanks mate also im going to get a pm tunning clutch 107mm
  7. lshigham
    lshigham Member
    Don't waste your money on a crap clutch, standard with stronger springs is sufficient for a sport kit. Also, the PM 360 pipe is pretty poor on a sport kit, you want something a little lower revving.
  8. mitch70
    mitch70 Member
    typhoon 70
    ok thanks is it the 3 or 4 springs on the clutch what about a hebo is that better i got that on my 50cc typs now with a malossi variator with rubbish rollers need better 1ns ,malossi boost bottle
