Tuning tips
Discussion in 'Newbie Scooter Tuning' started by tarkerz, Dec 18, 2010.
  1. tarkerz
    tarkerz New Member
    Aprilia SR50R
    Yoooh i have a CPI ARAGON GP50 PADDOCK, import shit i know, but i need more speed, so i was thinking, how much difference will this set up make?
    First set up -
    Stage6 Streetrace 70cc kit
    NGK spark plug & HT lead
    MALOSSI air filter (for the air box)
    Second set up -
    HEBO next generation variator
    Third set up -
    Stage 6 PRO REPLICA racing exhaust
    Obviously I would like to go for the cheapest option available, i'd just like to know which would give me the most power, I WILL be getting it all re-jetted, and correct rollers, i know a friend with a dyno :good: ALSO IS IT OK TO USE STANDARD CARB WITH BIG BORE KIT?! thanks.
  2. tErr0
    The most power will be
    Keep the standard air box.
    Sadly I don't really know much about CPI engines so I don't know if they are restricted by gearing like some other odd engines or how weak their standard transmission parts are.
    It's ok to use the standard carb but it depends on the size of it as to weather it will completely strangle the power out of your kit. I have no idea what the stock carb size is on a cpi.
