tuning!! jet recomendation?
Discussion in 'General Scooter Discussion' started by Dean_runner172, Dec 6, 2013.
  1. Dean_runner172
    Dean_runner172 New Member
    RUNNER 172. ICE 125
    gilera runner 172
    malossi 172
    polini 30mm pwk flatside carb
    pm tuning 360 pipe.
    pm boost bottle
    full circle crank
    stage 6 air filter
    malossi cdi.
    thats the spec. just need a jet to recomend as it has a 135ml jet and it only runs for 10mins then backfires and dies. then have to wait 10-15 mins to start again. think its over fueling. any thoughts on jet size?? cheers :)
  2. turbovetto
    turbovetto Well-Known Member
    tweaked ovetto
    Hi. No reccommendations for jet size but if it backfires, it's too poor, not too rich. get a box of jets in the range of 120 to 150 and start with a big one. Then work down.
    Good luck.
  3. Dean_runner172
    RUNNER 172. ICE 125
    It doesn't backfire all the time just before it's about to die?
  4. turbovetto
    tweaked ovetto
    Could be a depression pump / fuel like/ float bowl thing. Not enough fuel is getting in the bowl so as soon as the bowl runs dry you get the 'poor' symptoms. I'd check all hoses, clean the carb & check the depression pump works (suck/blow on the air pipe & see if the fuel runs freely from the fuel pipe).
    Good luck
