With this setup which crankshaft would be best? Malossi MHR Rep AC or Malossi Sport AC 70's. Malossi Multivar 2000 Variator. Malossi Delta Clutch and Clutch Bell-Yellow Clutch Springs Purple Torque Spring Stage 6 Short Viton Intake Manifold Stage 6 Viton Reed Block Malossi 19mm Carb Kit- (includes a Covered Air Filter) Stage 6 Primary Gear Up Kit 98 jet, 6 gram rollers. Visual Wise: Paint all exterior panels black. Paint all grey mouldings black. (Optional) Powder coat alloys dark blue or neon green or just leave them black. Spray the full engine case/ transmission black Get a side stand. Checker board foot decks. Get evil eye headlight stickers. (Optional) Design my own sticker set for NRG, send it off to get created. New kick start pedal. WHAT DO YOU THINK? ANY SUGGESTIONS?
becos it will requrire rings changing every couple of thousand miles and new piston every 5000 miles and its a rip off ...who is going to fit the crank
standard crank for now. aren't setting it all up yet. just listing the parts i want. & what crankwould you recommend?
Just priced it all up & its come to just under £1000, so going to re-think my set-up and ill post it on here once done x
