Just had a new rear tyre fitted on this Aprillia Mojito that I am working on......the problem is it is tubeless, and won't seal.....it has been suggested that I put a tube in it.....the tyre size is 130x70x10, and you can't get tubes that size, would putting a 120x70x10 tube in it work ? ....a trye fitter pal has suggested that the only proper way around it is to have the wheel shotblasted......anbody got any thoughts ?....
Get the tire off, wire brush, rough paper the inner rim, give it a squirt of silver paint or take it to a tire fitting shop and ask them to run some "bead sealer" round it.
Thanks for that......it may be the only option, as I now see that you can't get 120x70x10 tubes either......
There's no wonder the bugger wouldn't seal.....look at the state of this !!.......wire brushing here we come.......
HANG ON A MINUTE!!!! I quote........"Just had a new rear tyre fitted on this Aprillia Mojito that I am working on" If you just had a new tyre fitted......and the rim is in that state.......WHO THE HELL DID YOU TAKE IT TO??????? Please name and shame........ There is no way in hell that anybody worth their salt would fit a tyre on a rim in that state........ If that's a mark of their standard of workmanship, stay the hell away........ Now, get one of these: https://www.machinemart.co.uk/p/cht558-75mm-wire-cup-brush-m10/ Fits onto a standard 4" angle grinder, and clean up that inner rim BTW, wear rigger gloves and goggles when using it, you WILL get multiple strands of the brush stabbing into your hands otherwise
It was a freind of a freind........I should have known better......I'm now doing what I should have done in the first place, doing it me self......
For the record, a ten inch tube is a ten inch tube, pretty much.... But yeah. Go slap the guy who did that.
Well it would seem that you CANNOT get a 130x70x10 inner tube, you learn something everyday I guess.....still busy cleaning the rim up, and waiting for the angled valve delivery......hopefully get the tyre fitted on Friday......fingers crossed !!
Like I said. It's just a ten inch tube, the sizes are marked like "120/70 110/70 100/70 120/80" blah blah it's all the same box.
Thanks for that, so in theory you could put a 120x70x10.....or maybe a 100x70x10 in, and it would work ?....hopefully won't need to, as the rim has come up really well.... but would be nice to know.....
As skuba say's, the 120/70 is width/ profile (sidewall) of tire, it's only a 10" so a 10" tube would work BUT ! I'd only ever use one if I was stuck in the desert, not long term fit.
You'll probably find that you don't need a tube now the rim is clean again.....just make sure none of that crud has come off the rim onto the tyre bead.
Thanks for that, yes will inspect the tyre closely......I think if anywhere had been open I would have had the whole wheel shotblasted, the rim is coming up o.k, but the outside of the wheel is pretty poor.....I'm guessing that these wheels are powder coated ?
Just goes to show that you should LISTEN to people that know......the wheel and tyre is now at the local ATS depot....it wouldn't seal.....I told the guy that I had spent 3 days wire brushing and sandpapering the rims....he said "Ah, but have you painted them ? " I said "err, no"....he said "that's why it won't seal".......should have listened to Marsh's advice in the first place.....you live, and (hopefully) learn I guess.....picking it up in the morning....
The tyre is now on, and holding air....unfortunately the directional arrow is facing the wrong way, so taking it back in the morning.....
