Trying to disassemle showa forks?
Discussion in 'The Workshop' started by speedy-demon, Mar 27, 2013.
  1. speedy-demon
    speedy-demon ■□■□■□■□■□■□
    Like a pro
    basically i baught some used vivacity forks to convert my speedfight, iv removed the oil seal, dust seal and circlip and sprayed them with loads of WD40 but there not coming apart, iv even tried heating the fork tube but no good. :mad:
    i found this link with a picture of it in bits
    http://www.scooternations.com/showthread.php?195-Freeing-USD-(Up-Side-Down)-forks
    i cant find my haynes manual after tearing the house and garage apart!!
    anyone rebuilt or changed the seals in showa USD's??
  2. speedy-demon
    Like a pro
    Many not! i managed to heat up and remove the bottom.. :)
  3. Stig
    Stig Well-Known Member
    EXUP1000
    theres usually an allen bolt or similar in the bottom of the leg that holds the toob in
  4. speedy-demon
    Like a pro
    yh i took the bolts out and they only hold on the bottom parts, they might be pressed together as the picture thats in that link shows a set of forks with the top cut off so maby there not supposed to be taken apart.. its all good now tho iv ordered some fresh seals and polished up the legs just need to paint the tubes and bottom pieces then there mint
