Hey Guys, After clocking up about 300 miles in two days went to start my bike this morning to find out that i would get half a meter and then it would stop. The 2 stroke is filled up and there is petrol in it. Just wondering what this could be.. Description: Mini revs and it pulls then cuts out and full revs and it just cuts out after about 1/2 meter and then when i last tryed turning it over it just wouldnt turn over does anyone have an idea of why this happened? My oil light did come on and i filled it straight back up. Thanks Travis
sounds like a vacume pipe has come off or split untill you said it wouldn't turn over. either a totaly dead batery or most likely seized
Sounds like it could be running REALLY lean, check the manifold for splits, check the airbox rubber pipe for splits and check its on properly, also check the airbox is not leaking air from anywhere else.
