Transmission case removal
Discussion in 'The Workshop' started by Mp, Feb 24, 2009.
  1. Mp
    Mp New Member
    Hi,
    Wondering how to get the metal transmission case off?
    (Case that protects drive belt, variator etc)
    Tried moving the nuts but there not shoving at all, any suggestions?
  2. MiNoR cOnFuSiOn
    get a DECENT metric toolkit :confused: read your manual... and dont take it off befor you have half an idea (the cover is the easy bit, if you cant sus this out just yet i woudlent want to know about you playing wiht things that reach 30,000rpm+)
  3. Mp
    Mp New Member
    ... I've got alot of good metric tools, the nuts are extremely tight wont move at all, I know exactly what to do after getting the case off, just wondering if anyone had any tips such as abit of WD40, or a special way to remove it instead of sarcasm, as it doesn't help at all.
  4. Dec
    Dec Active Member
    nothing ugm
    heat gun/impact wrench and wd40 if theyre really stiff mate.
  5. Mp
    Mp New Member
    Cheers mate, yeah there tight, wouldn't be surprised if someone wielded the things in really not budging at all
  6. Vesta
    Vesta New Member
    might be loctited in
    get a breaker bar and twat it with a hammer, might wanna put a bit of a rubber glove in the socket so it dont round the bolt
  7. bait
    bait Active Member
    i had similar problems whatever you do dont get fucked off with it and try prying the cases of will cost ya make sure ur using the right socket and try not to round them
  8. wobbly_trials
    it's corrosion mate, the steel bolt reacts with the alloy cases and seizes in the threadds solid.
    get a heat gun and get the case as hot as you can, then using a good 8mm socket or 5mm allen key (depending on what kind of bolts you have) try unwinding them, the trick is not to use excessive force as they do shear off quite easily, then its a case of drilling and tapping the remains out. a good soaking in WD40 for 24 hours will help too.
  9. Mp
    Mp New Member
    Cheers wobbly mate, yeah ive used about half a can of the WD40 and managed to get out two, rest aren't coming out - i'll try the heat way tomorrow unless it rains
  10. shinigamii
    shinigamii New Member
    tits and tits.
    Lol use a single hex socket aswell that way it ensures you ahve a good tight hold, multi hex are good but not for tight things they have a tendancy to round. Same with spanners.
  11. wobbly_trials
    yeah a 6 sided is a MUST the 12's are crap and eat the head of the bolt.
    well thought of.
  12. Mp
    Mp New Member
    Heatguns are abit to heavy though, probably use a hairdryer and I don't mean it weight, I don't want a load of black marks and dripping paint over my casing lol
    EDIT: and yeah there the 8mm bolts
  13. wobbly_trials
    i always use a heat gun, get the metal quite hot and it burns the corrosion out of the threads. shouldn't get dripping piant unless your transmission case is painted.
  14. Mp
    Mp New Member
    alright then, as they break glass and burn wood easily :D
  15. wobbly_trials
    just thought, some have a plastic case on the outside, that may melt.
  16. Mp
    Mp New Member
    Nah, it's nice and sturdy metal - Would hate for it to be plastic lol
  17. phi1
    phi1 New Member
    Just don't snap all the bolts off in there! try with wd40 and leave it and then try again could also try with a small blow touch
  18. MiNoR cOnFuSiOn
    erm, crv sockets wont ever round a bolt off... fuck 6 sided, want sockets that hold the middle of the nut flat not the corner.. argos shite.
    NEVER had a prob getting tranny cover bolts out. they shouldent be that tight anyway, just enough to not come out. the structure is there with all 15 hand tight afterall.. more likely to crack a case from the\m beinbg too tight. if youer having real trouble just grind all the heads off the nuts, get the case off and the tention through the bolts will no longer be there, the wd 40 can get into the thread and you have more than enough to mole grip the remaning stufd.
    this has happend for a reason, id be guessing the wrong length/diameter bolts (mabey imperials) done up wWAY too ticht. ive ripped some SKANKY old engines and even then they snap befor tyhey round off. get a GOOD cr-v long reach socket and get your elbow on it :confused:
  19. wobbly_trials
    i've had this with a few, got one at the moment, its not an old motor, original bolts, just corroded in. i know that most arent going to survive, just means using good molies and wd40/heat when they do break off. or at worst drilling and helicoiling.
  20. alperin
    alperin Active Member
    aerox 180cc
    angle grind the nuts heads and then drill dem out.
