alright guys, ordered the following parts, Stage6 performance variator Stage6 pulley (kickstart only style) new kickstart shaft new kickstart spring lock nut washer (for kickstart) kevlatr drive belt new variator caasing bolts new kickstart lever new mirror oh and a cdi unit that will get rid of the rev limiter. was just wondering how the set up would work, it comes with 6.5g rollerrs ( sounds a bit heavy to me?) and a 'medium' contrast spring. will these go well with my leo vince TT exhaust? also if i put the unrestricted cdi on, what are the pros and cons, and is there danger of blowing the engine? thanks.
Nope, your standard CDI is NOT restricted anyway, it just retards the ignition at very high rpm, your engine will not rev that high with the specs you've got. Its only worth doing if your engine is capable of 14,000rpm++
