Top Racing 4 Part Gear Up Kit
Discussion in 'Scooter Tuning' started by tommo10, Aug 17, 2011.
  1. tommo10
    tommo10 Member
    aerox70 kx250
    I want to purchase a gear up kit primary or secondary, or both. I came across Top Racing 4 Part Gear Up Kit, and was wondering if it's primary secondary or both? And does anyone know if it's any good?
  2. Jonnymarrw00t
    Piaggio Zip 05 plate
    What setup do you have ? Unless you're more than Mid-race I would just go for a single polini gear up. I've never heard of TopRacing....
  3. tommo10
    tommo10 Member
    aerox70 kx250
    my setup:
    polini sport 70
    polini high speed variator
    polini uprated tourque spring
    polini 2g clutch
    polini kevlar belt
    dollleroto 21mm carb
    pm360 pipe (but looking to get a new pipe)
    Would you recommend me getting a primary or secondary polini single gear up kit?
  4. Jonnymarrw00t
    Loose the 360 lol. And i'm not sure dude. I've got a polini Secondary coming for my bike.
  5. tErr0
    A gear kit is a gear kit. You only buy one and normally the best idea is to go for a stage6 primary as they are pre-pressed so it's an easy job to fit them.
    All of this you would have already found if you used the search.
    Do you have a link to the part you are on about?
  6. tommo10
    tommo10 Member
    aerox70 kx250
  7. tErr0
    That's a kit with both primary and secondary in it. You don't want to be fitting both gear ups to your bike. But you know that already after searching.
  8. tommo10
    tommo10 Member
    aerox70 kx250
    thanks for the help :)
