Top box lost key!
Discussion in 'General Scooter Discussion' started by Wizard2003, Jun 1, 2017.
  1. Wizard2003
    Wizard2003 Member
    So I have an old but in very good condition top box that I was going to use. But I can't find the keys for it anywhere!
    Is that something that can be changed out for a new lock or is it for the bin?
  2. Stevep
    Grab a 3mm drill.
    heat up the solid end to cherry red
    push it through the blank side of the hinge pin
    This allows you to push out the hinge pin, opening the back of the box, when you can then use a Phillips screwdriver to undo the panel over the lock and remove it to be replaced with a new lock and 3 keys.
  3. Wizard2003
    Wizard2003 Member
    Thanks steve! I suppose I would need a specific lock for the make of box?
  4. Stevep
    Not sure really, what box is it?
  5. Wizard2003
    Wizard2003 Member
    Only had a quick look at it. Still at a storage garage so will have to get it home and have a proper look!
  6. Wizard2003
    Wizard2003 Member
    Crisis averted!!
    :oops: keys were in the box! :confused:
    It wasn't locked I just thought it was!
    Stevep likes this.
