Ok time to order just wanna confirm it with you guys so I don't get nothing wrong. Polini Sport 70cc kit Stage 6 21mm Carb Stage 6 V-Vorce 3 Reedblock ( will I need to buy reeds for this ?) Stage 6 Hpc Crankshaft Stage 6 Crank bearings Polini Speed Control Rollers Jets I think that's it other than a PM gear up, What you guys think ?
No need for the following : Stage 6 Hpc Crankshaft Stage 6 Crank bearings Its an 08 aerox....the crank and bearings will last quite a long time before they need replacing mate....spend the money on something else.
firstly, you've made some good choices, what mehmet has said is true in a way, but running a full circle crank will help performance, and also peace of mind knowing you have a decent crank should you ever want to change the barrel etc. good choice on the reedblock, yeh you will need some carbon reeds, polini do some pre-cut for the block now i think. running a polini sport on a zx is ok, theyre not the best pipes as you know but its the pipe you've got. finally, dont bother with the gearup just yeh, you need to see if you're even close to pushing the gearing boundary before you spend.
I dont think he will go futher than just bolt on performance...so the crank should be fine for a year or 2 maybe more depending on how you set it up. Spend the money on a better pipe.
Sounds good no point on buying stage 6 bearings I would just go to the bearing shop and buy c3 bearings cheaper
Ok thanks guys, so i dont need the crank is what your saying or gear up ?, in that case ill either get a Laser X-Pro or Pm Tuning X-Tech 360, really i want a road legal pipe does the C16 Come road legal and chromed ??? Also another question is there any little things i need like spacers for the reed valve, gaskets, shit like that ??
Dosn't The Polini Sport kit come with reeds ? also, will i need any other bits, other than jet, rollers
i domnt have any experience with the hepo or the doppler but i do have experience with the lazer i would suggest anything other than the lazer is a good choice
Polini Sport 70cc kit Stage 6 21mm Carb Stage 6 V-Vorce 3 Reedblock Malossi Multivar Stage 6 Drive Face Polini Evolution 2G Clutch Stage 6 Wingbell Modded Airbox Polini Kevlar Belt Exhuast of Choice - Hebo? Rollers Torque Springs Clutch Springs i would go for something simular to that. . Mixture of what you've got and what your need, What you reckon mick?
