Throttle Slide.
Discussion in 'The Workshop' started by xenovia, Apr 16, 2008.
  1. xenovia
    xenovia New Member
    Can't seem to get the throttle slide to go in properly. When I push it down it goes down fine, then when I try and tighten up the screw on top, it spins around. It wont screw into the right position. Am I doing something wrong, or is there a solution to this?
    Thanks.
  2. kyle1b1
    you lidned the little notch up with the grove ?
  3. xenovia
    xenovia New Member
    i did, then when i try and put the cap on (the throttle cable cap thing) it spins, so I can't get it to line up.
  4. kyle1b1
    dont know wtf your on about :rofl:
  5. xenovia
    xenovia New Member
    lol its hard to explain, but sw1ft gave me some advice so I'm gonna try it out tomorrow.
  6. MiNoR cOnFuSiOn
    there should be a little plastic/metal pip inside where the slide goes.. chances are youve forced it out. look for a hole on the inside wall then on the outside push whatever is blocking the hole then line this up with the slide when you bang it back together... just hope you havent fucked/lost the pip as its a nightmare to fix without jus buying a new one an there a bastard to get bits for :(
  7. xenovia
    xenovia New Member
    you were spot on minor, and with yours and wobbly's help i got that pip back in (hammer and screwdriver).
    Now I just need to get it to idle. At the minute it takes lots of kicks to start, then it idles very low, then it has a big rev and then cuts out. :wtf:
  8. alperin
    alperin Active Member
    aerox 180cc
    erm i think ur bike is taking air in from somewere lol
  9. kyle1b1
    idle mix !
    have a play with that so that it responds well when you blip the throttle and dosent bog or anything then get it warm and set the idle speed
  10. xenovia
    xenovia New Member
    Dont think it's idle mix, as I havn't altered it from when it was working well.
    taking in air sounds right. I can't think from where tho.
  11. MiNoR cOnFuSiOn
    missing o ring in the top of the carb? missing vacume pipe.. have you loosened anything off? is the needle in the slide? is the plate ontop of the needle?
  12. xenovia
    xenovia New Member
    not sure about o ring- where is it?
    vacuum pipe is on
    needle is in slide
    plate is on needle- i think
  13. MiNoR cOnFuSiOn
    make sure its not the other way round... put the top on the cable, then the spring bunched up in your hand. needle in the slide, cable in the slide then place the plate in and let go of the cable
  14. xenovia
    xenovia New Member
    still no luck. tried most things.
    It takes a couple of kicks to start. Then very low idle speed. Then very high rev, then dies, and if i blip the throttle, it'll stick for a few seconds (not the actual throttle) but the revs will stay high for a second or two without throttle, then drop again.
  15. kyle1b1
    check for air leek if not have a play with idle mix.
  16. wobbly_trials
    i would suggest you check your reeds are closing. it could also be a base gasket leak
  17. xenovia
    xenovia New Member
    it was a base gasket leak.. had a rip straight through it
    runs like a beaut now :up: :up:
  18. MiNoR cOnFuSiOn
    ye deffo sounds like air.. does it pop a little?
    if its got the airbox on spray wd40 around the carb when its running.. if the revs change atall theres an airleek so whip everything off, clean and assmeble with a fine smear of fuel resistant sealant (ideal would be lap the reedblock top face) but may be a split somwhere.. ether way this will tell you wether to mess with the idle mix
  19. xenovia
    xenovia New Member
    i reckon we've got an air leak, it wont settle down on the idle. I start it and it idles really high, then dies down and cuts out, then wont start again. Also when i take the throttle slide out its fairly wet with oil i think- i dno if this is right?
  20. Sw1fT
    Sw1fT Active Member
    200SX S13
    check the reeds and the seal around the reed block.
