Throttle slide reassembly problems
Discussion in 'The Workshop' started by Saracen, Apr 29, 2019.
  1. Saracen
    Saracen Member
    Been kneeling beside my Zip 50 2T all afternoon without success. It's a Dell'Orto PHVA 17.5 carb and I can't get the cable back onto the slide.
    Never come across this plastic white clip before and all it seems to do is get in the way, I think I have the parts in the correct order but the clip makes it near impossible to correctly locate the cables' nipple into the central recess on the underside of the slide.
    Has anyone encountered this horrible set-up before and managed to sort it out. Any tricks or tips would be really helpful.
    Thanks
    [​IMG][​IMG]
  2. milo2025
    milo2025 Trip to Trumpton
    That looks like some kind of springy thing. Have your tried with some tweezers or even better a set of needle nose pliers?
  3. Sam phantom
    Sam phantom Active Member
    Yes we have it on our runner, you need to pull the spring back as much as possible so the cable and nipple are exposed then locate the nipple in to the correct position in the slide then the plastic bit will drop down inside the slide when you let go of the spring. then spin the slide until the raised bit on the white plastic retainer sits in the hole in the side of the slide
    milo2025 likes this.
  4. Saracen
    Saracen Member
    Hi Milo,
    Thanks for your advice, I'll give it another go tomorrow.
    Sam,
    Just what I was looking for, so you've been there and sorted the problem.
    The Haynes manual is a little vague, one of those, 'installation is the reverse of removal' instructions.
    Also makes you think what was wrong with the old 'W/M' clip. They used to be quite easy to do.
    Why do they have to change things?
    Anyway,the details you mention are spot on, I'll try again.
    Thank you.
  5. scubabiker
    Urggghhhh... I hate those damn things...
    Seriously....
    Only an Italian would make that huh?
  6. Sam phantom
    No problem good luck. just a case of holding that spring and white retainer back while you thread the cable in to the slide the rest should follow
  7. scubabiker
    And then slipping and launching the whole lot across the floor...
  8. Sam phantom
    :DFirst 5 gos yes lol
    scubabiker likes this.
  9. scubabiker
    You are in the danger zone...
    You think you have the knack, but one time, when you least expect it...
    PING!
    Goodbye needle....
    Dellorto: 1
    Sam: 0
    Sam phantom likes this.
  10. Sam phantom
    Saracen?? What’s the score ? Dellorto winning or loosing
  11. scubabiker
    He has lost the clip after springing it across the floor, then he lost the plot....
  12. Saracen
    Saracen Member
    Hi gents,
    Apologies, haven't been able to work on the Zip yet but I hope to try again later.
    Fortunately I have a spare clip in case the original goes skyward.
    I will report back.
    Thanks
    Sam phantom and scubabiker like this.
  13. Saracen
    Saracen Member
    Hi,
    Well I made sure there was as much slack in the cable as possible, next I followed Sams instructions and.......the plastic clip took off into orbit.
    Joking. I think we have success, at the first attempt. The nipple is in the right place, the adjacent hole in the slide is blocked, the plastic clip appears to be square in the slide and the Zip started as usual.
    I will go for a short run later but I am a very happy bunny.
    Thanks to the forum members and especially to Sam for passing on his tried and tested method.
  14. Sam phantom
    Your most welcome
