Throttle Kit
Discussion in 'The Workshop' started by robby_typhoon, Jan 23, 2011.
  1. robby_typhoon
    robby_typhoon New Member
    Hi guys
    I am so pissed off with this brake on my typhoon it will not bleed.
    What I want to know is is there any other throttle kit that I can use instead as in maybe nrg 50etc?
    I want to put a proper brake on but the typhoon one throttle cable is too close to handle bar and doesn't allow me to fit the front brake master cylinder?
  2. tErr0
    One off a gilera runner, zip, nrg... Anything with a front master cylinder.
    You also have to cut the handlebar panel to get the master cylinder to fit under it.
  3. robby_typhoon
    Hi Terro
    Do I just use the trottle kit or do I have to change the cabling as by the looks of it the typhoon screws in and the gilera has a clip on the end?
    I have been offered a throttle kit off a gilera 125 with the cables attached so these may attach to the carb and oil pump?
    Cheers
  4. tErr0
