Throttle cable issue
Discussion in 'The Workshop' started by CEEKAY_NG, Feb 12, 2012.
  1. CEEKAY_NG
    CEEKAY_NG New Member
    Peugeot Trekker 50
    Alright guys:) problem after bloody problem with my ice:/ my throttle cable snapped:/ so I bought a new one fitted it and it ticks over fine and all is good but when I put my throttle on when its on the stand it's all fine but once am sat on it and about to pull off it just bogs:/ any help guys would be a helpppp!:) thanks
  2. creamsodauk
    creamsodauk Ped Ped!!
    Runner 125 SP
    everything tight and secure on the carb? no air leaks etc round the inlets. i dont see how the cable would cause bogging as you can wind a ped throttle wide open from a standstill and it shouldnt bog
  3. CEEKAY_NG
    Peugeot Trekker 50
    That's exactly what I thought just checked it all over and it's all good but still same issue:/ it smoking like a bitch too! So I adjust my mixture screw smoking stopped and it pulled off but bogged around 25/30mph :/
  4. creamsodauk
    Runner 125 SP
    hmm i wouldnt go adjusting the mixture screw if you havent altered the bikes tune or running specs. clean the spark plug up and check that nothing has been knocked, did you take apart anything else? carb float jets area etc etc
  5. CEEKAY_NG
    Peugeot Trekker 50
    Well I had to take the throttle out of float so there float was out and I had to disconnect throttle from oil pump cause I couldn't disconnect the throttle from the splitter
  6. CEEKAY_NG
    Peugeot Trekker 50
    If that makes any sense?
  7. creamsodauk
    Runner 125 SP
    sort of, you need to go back and receck everything is corect, you may have knocked the carb float pin out or anything. chances are you have moved or knocked somthing and it needs putting back right.
  8. CEEKAY_NG
    Peugeot Trekker 50
    Okay I'll have anther check thanks for your help:)!
