Malossi 70cc sports laser x pro doppler stage 6 boost bottle Malossi variator kit malossi rollers ANythink else u think should be considered in this set up ?
lol ok. im not going to lie, a bosstbottle does fuck all..... but yeah bigger carb deffinately mabye a 21 ml , or a standard 125 carb (20.5)
Polini sport 70 Laser Xpro 21mm Dellorto carb Polini speed control kit and some rollers, jets and clutch springs will be bout 330 quid and a good quick setup too
altho a little more expensive stage6 sport pro kit stage6 pro exhaust 19/21mm carb + jets+inlet variator +rollers+belt will be a quick little sport and boost bottle are mainly effective on bigger carbs not standered carb those of oyu that run bigger carb may notice when u throtle off and de-cellerate then throtle back on it maybe a slugish responce the boost bottle nutralises that and gives instant responce , economy is slightly better
have you run this setup against others? have you ever set a carb up properly then put a boost bottle on there? ITS AN AUTO
