The Yasuni "City" 16.
Discussion in 'Scooter Related News' started by tErr0, Dec 7, 2006.
  1. tErr0
    A new Yasuni exhaust has been released.
    It's an E-Marked version of the Carrera 16. All of it is made out of lots of little pieces insted of being die stamped like the C16 which means it has a hell of a lot more strength.
    Kinda makes sense when they are advertising it as a road pipe now doesn't it. ;)
    It has two restrictors like the Yasuni Z and R. One where it meats the barrel and one in the end can.
    All in all it looks like a great exhaust.
  2. scottnrg
    scottnrg New Member
    exhaust
    do you no if it is easy to derestrict the exhaust cheers
  3. connor
    connor Active Member
    im sure its just a litte cone with a little spot weld on to hold it can jus knock it off im sure.
  4. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    yeah that one is easy, theres also ona in the can.
  5. nrgandy
    nrgandy New Member
    its easy as owt if you have a dremel
  6. scootertuningbinney
    scootertuningbinney New Member
    yamaha jog rr
    in the c16 it a tube with slits in to le the gas's threw with 2 spot welt holding it in place thats the one in the end can the one in the flange (hence the peice that meets the head is a washer spot welded in but like the chap says above its easy with a dremel if you ant got one a chissle ;)
  7. Dwaine
    Dwaine Member
    piaggio zip
    is there any way of knowing what model yasuni exhaust i have,,its the carbon can with big white YASUNI lettering onit with a welded bagde saying yasuni racing.And under neith says not for ROAD USE hahahahahaha
    thanks
