Haven't got pictures of what it first started out like, I bought it in OK condition (RED), few scratches but on my front panel the plastic that goes in between the headlights had snapped off. I bought it for £600. But it did come with Leo Vince ZX exhaust. A bit pricey for the bike though I know.. First thing I did was buy a new front panel, prep it, colour chip it and paint it at work. Next I removed one mirror and the rear mudguard. So far, thats all i've got D:! THINGS TO DO: Visual Wise. Paint all exterior panels black. Carbon wrap grey plastics. (Optional) Powder coat alloys dark blue or neon green or just leave them black. Spray the full engine case/ transmission case dark blue or neon green. Get a side stand. Checker board foot decks. Get evil eye headlight stickers. (Optional) Design my own sticker set for NRG, send it off to get created. Paint front grill dark blue/ neon green. New kick start pedal. System Wise. Malossi sport 70cc Kit. Polini hi speed variator kit. Yasuni Z Exhaust. Covered Malossi air filter. Stage 6 primary gear up. Malossi belt. PM tuning clutch. Stage 6 clutch bell. Malossi clutch springs. New rear shock absorber. Malossi brake calipers. Stage 6 Quick Action throttle. Reply & tell me what you think. Any suggestions or anything let me know. Also I could do with what rollers and jet size I should use. Thanks.
Swap out the yasuni z for a yasuni r. and sounds good. Ain't you going to get a new crank ? Also can't see the pictures.
I've been look ing around and here is an updated version on 'SYSTEM WISE'. All Visual wise will stay the same. Malossi sport 70cc Kit. - £130 Polini hi speed variator kit. -£40 Yasuni R Exhaust. -£140 Polini air filter 37mm (covered) -£17 Stage 6 primary gear up. -£56 Malossi belt. -£30 Malossi Delta Clutch & Clutch Bell Set -£87 Malossi clutch springs. -£15 YSS Mono X-Pro Shock Absorber -£40 Malossi brake calipers. -£ Around 20 Stage 6 Quick Action throttle kit. -£45 Tell me what you think..
if you all the measurements for the stickers ..i can get them made cheap and get the same guy that will do the wrap to fit it if you want ...or you could wrap the whole bike in carbon fibre or another colour or sumet
With a QA throttle on the standard 17.5mm carb you will basically just have no throttle and full throttle they arent really necessary imo. Spend the money instead on a 19mm or the runner 20mm i reckon
he means where the number plate goes it has a bracket that also has the indicators build onto it. in the picture he has posted he has got rid of that and got a tail tidy with aftermarket indicators on the undertray panel
