"the squish" Can someone please explain to me what it is?
Discussion in 'The Workshop' started by Stevep, Apr 23, 2014.
  1. Stevep
    Hi guys n gals,
    I've got this "squish" thing rattling around in my head and i need it to be explained to me in lay-mans terms please. I've read people saying they got the squish down to .58 and i presume they mean the base gasket or head gasket, but from my days of training you put the gasket on, torque it down to the right spec and job done. Is this the same as "the squish"?
  2. jayvinci
    jayvinci Member
    The squish is the distance measured between the piston and cylinder head at tdc buddy :)
    Stevep likes this.
  3. Stevep
    Ah, right:) thank you.
  4. turbovetto
    turbovetto Well-Known Member
    tweaked ovetto
    Just one comment- getting the squitch down to a small value is not a recipie for instant power. But it can be a recipie for pre-detonation, holes in pistons and all manner of other woes.
    Respect the manufacturer's spec, and if in doubt, go a bit bigger.
    And if it says 0.7 or lower, you need to use the highest octane fuel you can.http://www.vintagesleds.com/library/manuals/misc/Two-stroke Tuner's Handbook.pdf
    Page 33 of mr Jenning's opus. Interesting read.
    Stevep and MARSH like this.
  5. jayvinci
    jayvinci Member
    Mines running 0.58mm but I only ever run it on shell vpower :)
  6. Stevep
    So how did you achieve this squish figure? By overtightening the bolts or using different gasket sizes?
  7. scootzmadness
    squish? fuck that. my piston hits my head.... getting something or the other machined by the lad thats rebuilding my engine... :rolleyes:
  8. MARSH
    I never run a squish lower than 0.8mm on an L/C engine and about 1.0mm on A/C.
  9. jayvinci
    jayvinci Member
    Different gaskets and if none is thin enough machine a bit off the head :)
