The right gear oil
Discussion in 'General Scooter Discussion' started by MrXT, Sep 9, 2015.
  1. MrXT
    MrXT Active Member
  2. scootzmadness
    should be fine. its the stuff I use anyway and never had any problems.
    silkolene do a bottle that's similar for scooters specifically but cant find anywhere online that does it, that's good oil too. might be worth popping to local bike shop.
    MrXT likes this.
  3. MrXT
    MrXT Active Member
    Whats the best way to get it in from a large bottle like this? My scooter takes 200ml. Last time I used a 10ml seringe and did that 20 times which was a pain is the arse (knees) is there a trick or cheap product I can use to get the right amount in there fast?
  4. scootzmadness
    theres two ways -
    measure it in a jug and use a small funnel and pour 210ml in there (theres usually a spillage so add a little extra to allow for it)
    just use the above method but straight from the bottle until the fill hole overflows. that means its full. Its the way I was taught anyway.
  5. scubabiker
  6. MrXT
    MrXT Active Member
    Can't use a funnel because the fill hole is a bolt that's sideways so its an absolute pain in the arse. Theres also a warning in the manual not to fill it to the top in bold writing saying it only fills half way. On the kymco forum it also warns not to do that as filling it to the top would be almost double the amount of oil needed.
  7. scubabiker
    One of those squirty oil cans?
  8. scootzmadness
    oh right.
    maybe just use one of those squirty things you get with calpol sometimes? syringes?
  9. scubabiker
    i think the fill hole is the measure hole on those so fill it till it starts weeping out the hole and that should be 200ml? i could be wrong though
  10. scootzmadness
    which is why the fill hole is where it is and why I was always taught to fill it until it starts coming out....
    its always been that way on every scoot ive had/worked on and never had any issues doing it that way...
  11. MrXT
    MrXT Active Member
    Bought a 100ml syringe off ebay. 2 fills and its done sorted.
  12. twodogs
    twodogs Active Member
    scooters
    when I do my landrover diffs and gear box I use a length of pipe poke one end in filler hole put funnel in other end measure out amount of ep90 then slowly pour in to funnel ,let gratify do the work a warm day helps
    scubabiker likes this.
