been taking an absolute age to doing this one for the usa ,but it should be safe in ZX9RIDERS hands now. he has a drum dragster and wanted to go disc so i came up with a case and eventually sourced all the other bits (apart from the 172 kit which went from italy to the usa then to me )to make it a plug and play 180 cases 55mm crank malossi 172 reprofiled pm head well packed for the journey
hey shiny how much did all that cost him? i am asking because i was looking in buying a new set off cases and have you do the rest of the work thanks
The workmanship looks top class , good stuff I have a question is there a reason you cant get rid of the right angle in the intake tract Your not the only engine i have seen like this and i wonder why they dont straight line it Can you not fill the hole behind and grind into it
thanks :thumbsup: do you mean where it drops wax ,is on the list of things to try but had to stick with what i know works on this engine ,would be nice to know your thoughts though :good:
Im talking about this area , i dont know whats behind it so not sure if you can grind it out or if you can fill behind and then grind it out I understand a customers engine is not the one to experiment on but if you had a set of cases then this would be a good thing to try
nothing really the barrel studs are a bit further down ,would need filling as you say and it would take some primary away but its worth alook i will mill a slot in a scrap case and have a look . some pics of his peds with that many you can forgive the these two
Dont worry about loosing primary , its fine Its been proven that a good pipe will scavenge that hard it will actually open the reeds, this is why we have v-force reeds. I think the extra flow would more than compensate with any losses, this is ony based of what i can see in the pics email me at wax@waxracing.com i will send you a pic you may find interesting
Shiney i have to admit, your work is brilliant i would love to be able to polish tranny cases, engines like you and Print my own intials on other peoples engines
