Its also back on 17 inch rim on the rear as the +10cm swingarm wasn't long enough for the massive knobbly 18inch tyre. Even the 17 meant I had to cut part of the swingarm to fit it.
Not sure if it shows, but I cut part of the middle brace out of the swingarm. I've still not ridden it as my clutch has fused together due to being stood so long...
Anyway, here is where it is at now... Its too cold to do more with really. I need a garage so damn bad
So. Update time. This is a back burner project still. HOWEVER... My little helper/buttman has been assisting me with the white cub. Which has just had some VERY fun parts ordered for. https://www.pitbikeparts.co.uk/kepspeed-standard-width-springer-front-forks-bs0295-p-3615.html Springer forks. An underbody noisy exhaust. And 2 engines. Not sure which is going where. But here is one: https://www.pitbikeparts.co.uk/yx140cc-electric-start-semi-auto-p-3649.html I ordered a carb too. The other engine is a bit more sensible. For a racebike. You can all guess for a while. Also pitbike parts are the UK dealer for kepspeed. Good products.
The crosser one I think. Im not sure it will fit in the white one as the front wheel will touch the cylinder. I think anyway.
The 140 wheelies in 3rd off the power.... might be some footage from dgr stavanger 17 (or 16?) On youtube
