Technigas Next exhaust bracket for Peugeots with the Vertical engine
Discussion in 'The Workshop' started by Merlin, Jun 4, 2016.
  1. Merlin
    Merlin Old School Biker
    2007 TKR WRC 50
    Today I measured up and fabricated a bracket similar to the one advertised for the Technigas Next R exhaust. For those that are interested, it's basically a metal plate triangle with three M8 holes, with the hole centres spaced 90mm apart.
    I made one in aluminium alloy plate this afternoon and apart from some thread lock, some new M8 bolts, a 20mm long piece of steel tube that is a close fit for an M8 bolt (to fit between the exhaust and the new plate, as there is an offset), some washers and a nylock nut, that was it. It fitted first time and the dimensions for the holes were spot on.
    I allowed at least 5mm distance from the holes to the edge of the triangle and I rounded the corners off with a file. My alloy plate was about 3mm thick, so there's plenty of strength in it and it won't rot easily. It's a lot stronger than the bent steel plate that it replaced.
  2. Skete-vx125
    Skete-vx125 Member
    And much cheaper than buying a bracket, I really wanna make my own pipe to come up high and sit under the seat, like a super bike.. Think it would stand out from the others..
