tank cleaning help?
Discussion in 'The Workshop' started by weymesy123, Aug 23, 2012.
  1. weymesy123
    weymesy123 New Member
    petrol has been left in the tank open to the rain, leaves from the garden and air obviously for some time as been sat in the garden. about 6 months anyways.
    i want to clean the tank out as i have discovered this gooey sticky substance and i read i had to clean it and use fresh petrol for it to start.
    what is the best 'unprofessional' method to cleaning it, something i can use household items or will just boiling water and a swill few times do?
    any help appreciated, thanks.
  2. greekenigma
    greekenigma Member
    ok what i do is
    take tank off bike
    take off bottom tap valve (to check filter is not blocked up
    then
    take it to the bath
    get warm to hot water (not really hot cause it expands the plastic tank)
    add some fairy or whatever
    shake about and repeat a few times
    then add salt and warm water (salt will help scratch off crap)
    then shake about
    then after rinse out a few times with cold water (tp get out all salt and bubbles)
    then refit
    job done
    ps also check your jets are ok and not blocked up as bikes been sitting a while
    scubabiker likes this.
  3. greekenigma
    greekenigma Member
    you get it done?
  4. c0nn0r77
    c0nn0r77 Member
    Aerox 70
    Cheap diet coke works well too
  5. greekenigma
    greekenigma Member
    yes this works too
    but my idea of salt is very good
    as salt is abrasive so will scratch of the crap on the inside of the tanks walls
  6. Stig
    Stig Well-Known Member
    EXUP1000
    err...so the salt dont dissolve in the water?????????
  7. 172NRG ASH
    172NRG ASH build it, ride it, break it, start it again......
    nrg172cc,,runner70cc
    do this works perfect
  8. greekenigma
    greekenigma Member
    th
    thanks
    ps after you have done it
    take out the petrol level sender unit
    to make sure no salt or anything is inside etc
    i only do salt if its very very bad inside
    usually fairy and warm water does the trick
    but if it very very bad inside put in a small cup of salt and some water (just a lil bit of water)
    that way it stays abrasive and does the trick
    ps can someone change my screenname
    otherwise im going to have to delete account and remake
    cheers
    ps if you got sharp sand use instead of salt (even better guys :mad:) )
