Hi, i have a nrg mc2, the brake lights work, however the tail light doesn't work? I have replaced the bulb etc , does any body know why it wont work? thanks
Check the electrical connections from the stator up to the light switch, especially the ones to the regulator/rectifier. The horn, brake lights and starter work of the battery's DC circuit, but the head an tail lights work from an AC circuit from the stator. On a lot of bikes, the large multi-connectors behind the front fairing can work loose. If the headlight is working, then the tail light filament in the bulb has blown.
or you may find that the wire is broken behind the light itself. It passes through a hole in the rear of the frame and easily gets snagged and chopped over time.
i had this problem. turns out the bulb needed turning abit as crud or something blocked the connection, give it a twist. worth a try
i know the feeling! i couldnt work out what was up with it as everything checked out with the multi meter, and it wouldnt of passed the mot. i didnt know weather to laugh or cry when i finally sussed it its the first thing i do now when lights play up.
